holset turbo
I wouldnt use it on anything else than a diesel... they're small turbos used to take advantage of a diesels small rpm band..... internal wastgates arent good for anything over 15-20psi.. HAve you seen the turbo? So i take it if he converted it to external, he blocked off the internal wastegate?
Holset also uses volume for the turbine housing instead of A/R. There will be a number like 19, 20 etc. stammped on the turbine housing, or just inside of the inlet. That stands for cm^2. The smaller the number, the smaller the A/R. That would be an important factor to consider also.
I've used an HD2 diesel turbo (68mm I think, can't remember) with success on a stock cube LS1. I'm doing a build with a 58mm H1E right now.
Just my $.02.
Only drawback to internal wastegates are slow opening times and pressure creep..
got me...
