402 + F1 = Some fun
Old Jan 20, 2007 | 12:24 PM
TNTramair's Avatar
Originally Posted by GrannySShifting
Its not that bad after doing a F1C in a Fbody, you have to do a LOT of little stuff, but once we did LSS1Powers its not "hard" but pretty tedious little stuff. I think after seeing the torque it made, it may be the way to go. Turbo car torque curve without the plumbing headaches
when ya get some free time, could you possibly PM a little list of some of these things you had to do so we're not hi-jacking this thread....lol. im on the fence if i should stick to a D1 or step up to the F1 on my 402. i appreciate any help you can give me. thanx
Old Jan 20, 2007 | 04:06 PM
BLASTER's Avatar
I am in the same boat. If you guys are doing a little list could I also get some info. Thanks
Old Jan 20, 2007 | 04:24 PM
LTLHOMER's Avatar
Badass!
Old Jan 20, 2007 | 04:54 PM
TT402LS1's Avatar
So let me see. You ran it without a filter on the supercharger, but the BOV has a filter??? LOL! Just kidding. But I never seen a BOV with a filter.
Old Jan 20, 2007 | 06:32 PM
99Z28LS1's Avatar
this is just amazing, damn blower guys with your instant boost...... its ok, i'll get some twins in the future and hope for some faster boost
bad *** car and +100 for the #'s
Old Jan 20, 2007 | 06:34 PM
SinCityFD's Avatar
Danm the work wwp does is insanily bad ***!!.
Whoops my bad it was a late night HAHA
Old Jan 20, 2007 | 11:02 PM
HUNTER02SS's Avatar
Originally Posted by SinCityFD
Danm the work PPW does is insanily bad ***!!.
I thought it was Wheel to Wheel Powertrain. Who is PPW!
Old Jan 24, 2007 | 08:20 PM
Reckless's Avatar
Super Moderator
Well the goal for the customer was 1000hp and we got there today with only 6500rpm and 15psi of boost. We actually had to go up in size on the blower pulley to eliminate slippage and move the boost up in the power band a bit. Someone is going to have a fast Z06 if he can get traction.
Old Jan 24, 2007 | 08:21 PM
Reckless's Avatar
Super Moderator
That is the Procharger C5 Race kit as it comes out of the box. We did nothing to it except change the blower pulley once or twice
Old Jan 24, 2007 | 08:36 PM
corvettetimmy's Avatar
Thats inspiring.
Im shooting for approximately 850 rwhp with an f-1a and my 427 with l92 junk. I just need someone to go to my classes for me so I can work on my car all day .
Old Jan 24, 2007 | 09:34 PM
99Z28LS1's Avatar
just amazing what some people can do with the knowledge. i need to learn this and do it
+1 on the awesomeness
Old Jan 25, 2007 | 09:12 AM
  #32
ls1290's Avatar
Dumb Ass Vette Moderator
Originally Posted by Reckless
After the initial pulls we are at 894lbft at 5300 and 962hp at 6000 where the pull was ended. Both of these numbers were at 13psi.
Can you give the head and cam specs? For rear wheel, that is 787 for M6 and 740 for an A4?
Keith
Old Jan 25, 2007 | 10:23 AM
  #33
Reckless's Avatar
Super Moderator
I would think higher than that. We will see I guess. I don't think you can apply a percentage loss to every level of power. The losses are much less significant the higher you go. I would guess 850rwhp on an MN6.
Old Jan 25, 2007 | 11:06 AM
  #34
High Pressure's Avatar
what is the cost to build this motor 402??
Old Jan 25, 2007 | 11:15 AM
  #35
Got Me SOM's Avatar
is that run direct drive off the crank?
Old Jan 25, 2007 | 11:42 AM
  #36
turimo1's Avatar
Recklesss, do you have a dyno gragh so we can check the curve out?
Old Jan 25, 2007 | 12:17 PM
  #37
Reckless's Avatar
Super Moderator
I might be able to print one and scan it, but we actually are going to do a little more tuning on it. I will post something when we are completely finished.
It is a 8-rib serpentine setup right from Procharger.
The engine is one of our "boost ready long blocks" as seen here:
http://www.w2wpowertrain.com/pc-98-8...ong-block.aspx
Old Jan 25, 2007 | 12:24 PM
  #38
Sharpe's Avatar
Originally Posted by 427
The tape is just to protect the SC's polished finish. When the customer finally opens the box we want it to shine like new!!
Kurt
You guys are out of this world. If I ever win the lotto like my life plan calls for, You're going to be gettting a call from me. I don't even know for what yet, but I'll figure it out after I hit the Power Ball.
Old Jan 26, 2007 | 08:33 AM
  #39
427's Avatar
427
Sounds good!! I have that same plan!!
Kurt
Old Jan 26, 2007 | 04:50 PM
  #40
99Z28LS1's Avatar
you guya juat build some amazing stuff
+1
