turbo lt1 with this radiator?
Old Jan 25, 2007 | 08:20 PM
Snyper's Avatar
Default turbo lt1 with this radiator?
http://store.summitracing.com/partde...5&autoview=sku
it will fit and the hoses are in the right spot..just have to have one port welded in for the steam pipe..question is..you think this is too small of a radiator with a 550rwhp goal in mine? (t76-10psi)..its shorter than stock..but its alot thicker..and it would be GREAT if i could get it in there to make room for more ****.
Old Jan 25, 2007 | 09:12 PM
B18CYA's Avatar
I think its a bit small,
I'm doing a truck mani kit and going to cut the core support to free up as much room as I can get
I was looking at one in jegs for $200
over all its like 27" wide 17" tall with two 1" cores
is the one you are looking at 2 or 3 1" cores?
Old Jan 25, 2007 | 09:22 PM
otherwhitemeat's Avatar
i got a becool rad. thats about 5" shorter side to side then stock and it works fine with my turbo set up....... the only time i had a issue was when i had a powerglide tranny and trying to cruise at 3500rpms it got hot and had to pull over for a few minutes
Old Jan 25, 2007 | 09:43 PM
Snyper's Avatar
yeah well ill be doing some friday night cruises/racing but its a 6 speed and has a small cam..the turbo wont be spooling at all on the highway.
Old Jan 26, 2007 | 12:57 PM
Snyper's Avatar
anyone else?
