Tubing questions
Old Jan 31, 2007 | 05:45 PM
bigbird01's Avatar
Default Tubing questions
Im new to FI. I was just wondering if silicone elbows can handle high boost applications. If not is the only other option welding all the pipes together?
Old Jan 31, 2007 | 09:54 PM
Ping King's Avatar
how much boost? it depends on the ply count on the silicon
Old Jan 31, 2007 | 10:00 PM
Turbo Tech's Avatar
We've used silicone hoses on systems up to 20 psi, as long as the pipe is bead rolled and tighten properly you shoild be fine. Anything over 20 psi we recommend the wiggins style. There is nothing worse that losing a hose connection while racing.
