Ls7 Supercharger
Old Feb 1, 2007 | 02:50 PM
Hennytime's Avatar
im just going to have to give up modded now...a blown ls7...
Old Feb 1, 2007 | 03:29 PM
andereck's Avatar
Originally Posted by SSilverSSurfer
thats awesome, you should find some videos and pics, lol. thanks for the info
These are from the latest install, not the previous hotrod. There are modifications required for the F1C/F1R. Some items need clearancing and the hood liner will need to be removed.
Attached Thumbnails Ls7 Supercharger-100_0290.jpg   Ls7 Supercharger-100_0293.jpg   Ls7 Supercharger-100_0300.jpg   Ls7 Supercharger-100_0305.jpg   Ls7 Supercharger-100_0306.jpg
Old Feb 1, 2007 | 04:35 PM
99Z28LS1's Avatar
i love that, i wish i had that kinda money
Old Feb 1, 2007 | 05:33 PM
superchargedbandit's Avatar
He Is Making It Up. Alot Of People Brag About How Much Power They Have. Unless You Know Them Personally You Will Never Know.
Old Feb 1, 2007 | 05:41 PM
Ponyhntr's Avatar
What are you talking about???
Old Feb 1, 2007 | 05:45 PM
mahhddgtp's Avatar
What the are you talking about?
Originally Posted by 98turbls1
If you're going to do that wouldn't it be better to just swap out to better head gaskets....Also do they already have head studs from the factory?? If not then it would definitely help with head lifting...
Since the motor flows so well, I'm not sure if you'll be pushing through enough boost for that to be much of a problem...
I am not certain. If the pressure in the cylinder isn't the case, then quote me and tell me otherwise
Old Feb 1, 2007 | 05:55 PM
98turbls1's Avatar
Oh I'm honestly not trying to encite a heated discussion...It's just if you're already in there why not do more to have insurance of trouble free usage for years to come... I know that most aftermarket products (that are worth a damn) are usually much better than stock...IMO... I was talking about if you're going to use a F1X to do these things... If you were using a P1/D1 then I wouldn't think that it would make enough pressure like you said to make it a factor to worry about...
Old Feb 1, 2007 | 05:58 PM
mahhddgtp's Avatar
I know what you mean... If I had the money to do a supercharged LS7 setup, I'd have the money to do those minor things to promote the motor's safety.....
But what I'm saying is it may not be necessary.
Old Feb 1, 2007 | 07:01 PM
andereck's Avatar
I would never suggest that somebody install an F1C on a stock...anything. This car is getting a P1SC-1 which will be good for 620 or a bit more at the tire with about 5 psi.
The pictures are of an F1R test fit as its assumed that there are going to be more enthusiasts interested in taking the platform to an even higher level. Big power with the LS7 requires the supporting hardware like any engine.
Old Feb 1, 2007 | 07:04 PM
SSilverSSurfer's Avatar
bad *** pics andereck, im sure its gonna be a handful. and your right im sure there will be someone who has to has the big daddy on theyre Z06.
Old Feb 1, 2007 | 07:12 PM
bboyferal's Avatar
I think he was "responding" to the poster above him's sig.
Old Feb 1, 2007 | 07:19 PM
  #32
andereck's Avatar
Thanks for pointing that out. I was confused as well.
Old Feb 1, 2007 | 08:15 PM
  #33
02SSLE's Avatar
looks great.
