A couple question
Old Feb 1, 2007 | 11:56 AM
93 4mula's Avatar
Default A couple question
Building a custom built turbo kit for my LT1 where is the best spot to put the two o2 bungs at? Also I see some people that run those flex pipes.. Is there any big benefit to that besides bein able to move it a little bit? And last does everyone run 2.5inch piping on there kits? When is it nessicary to run anything bigger?
Old Feb 1, 2007 | 12:49 PM
93 4mula's Avatar
anyone
Old Feb 1, 2007 | 03:46 PM
otherwhitemeat's Avatar
about 8" out on the dp..........if you run solid motor mounts you don't need a flexpipe..typically......and you can use 2 1/4 crossover piping if you what to, but if ats a large frame go with 2 1/5.
Old Feb 1, 2007 | 06:43 PM
93 4mula's Avatar
So since Im am not running Solid Motor Mounts I have to run a Flex pipe so when the motor flexs.. Does it matter which pipe I put it on?
