92 LS1 FM T76 Build
Old Feb 21, 2007 | 11:35 AM
crazy02ss's Avatar
Looks like a sweet setup good luck!
Old Feb 21, 2007 | 09:14 PM
Ryan K's Avatar
Pathological Modifier
What is your log manifold made out of?
Old Feb 22, 2007 | 06:24 AM
25thredrs's Avatar
the log manifold is made out of the top part of a stock manifold and the log part is 2.5 pipe
Old Feb 22, 2007 | 07:54 AM
Ryan K's Avatar
2.5" pipe aluminized steel exhaust pipe? If so, its never going to last for two reasons.
1. that manifold is stainless steel that you welded it to, Stainless steel an mild steel grow at different rates.
2. If its ehxaust tubing, it is way to thin to handle the heat cycles and stresses.
Just my opinion, hope it works for you.
Ryan K.
Old Feb 22, 2007 | 09:53 PM
25thredrs's Avatar
I did not know that...I hope your not right...But oh well...I will just have to see how long it will last and redo it if it doesn't work....Its a learning experience too.
Old Feb 22, 2007 | 10:15 PM
BigJls1's Avatar
Ryan K.
Why are headers .063 and .049 thick. that manifold will last longer than the gaskets will. as far as SS and mild steel growing at different rates, that would only be relivate on something thicker than .125. Also he used a wire feed welder as aposed to stick. wire feed welds tend to be fairly flexible (yeild) which will take up any expantion rate differances.
Old Feb 23, 2007 | 02:08 PM
Ryan K's Avatar
Well first off, Turbo piping gets MUCH hotter than most NA applications. Its not uncommon for the hot side piping to get almost cherry just after a dyno pull, much less a drag strip or street race.
That extra heat combined with the growth rates and then factor in the dissimilar metals and that the MIG wire is most likly the wrong filler material for stainless steel... There are quite a few problems here.
Ryan K.
Old Feb 23, 2007 | 07:27 PM
Wnts2Go10O's Avatar
keep it goin man. im planning on a twin setup for my ls189
Old Mar 7, 2007 | 05:14 PM
25thredrs's Avatar
Just an update......
I've got everything done except for finishing up the exhaust and having the car tuned....Just installed my Racetronix pump and harness tonight..Everything seems to be working good.
