Oil return from turbo
Old Feb 11, 2007 | 02:25 PM
taillights's Avatar
Default Oil return from turbo
Can I return oil to drain plug or is that possible? I know I can return it to timing cover if I remove and tap it. But if I return it to the pan will this work.THANKS
Old Feb 11, 2007 | 02:35 PM
Smearin's Avatar
Your return should be above the oil level, so it drains properly
Old Feb 11, 2007 | 02:36 PM
y2khawk's Avatar
no, you need to return above the oil level in the pan. Unless you're pumping it back in, then it really don't matter.
any crankcase pressure with the drain into the oil will push oil back up the drain.
Old Feb 11, 2007 | 02:54 PM
taillights's Avatar
Thanks that's what I thought I just thought I would ask.
