OFI 4" downpipe with stock accessories!!!
obZidian, It's easiest to just rerun the powersteering lines using stainless braided power steering hose. I'm in the process of doing that right now. Here is a link with all the fittings and lines required. https://ls1tech.com/forums/forced-induction/367551-stainless-braided-power-steering-lines.html The only other thing you'll need for the install is a short piece of 3/8" rubber powersteering hose and two hose clamps for the return connection to the reservoir.
I ask because i have never done anything like that, modifying hard lines, and wanted to know if i should just go ahead and get a new set of lines or just deal with what i have already. Is there a specific tool, like a small mandrel bending tool, to do the job right?
On the power sterring lines...You should be able to bend them out of the way, but I would reccomend getting custom lines of some sort.
I made a 3.5" DP for you though so you dont have to worry about the lines.
