What size spring
Ahh ok so say if I am running the E boost 2 controller and want to run 10psi on the street. Do I turn the controller down to 10psi also?
Yes the controller you are using has to control the WG also... for your boost setting......
watch it also about getting to small of a spring.....
I have a 7psi thats my lowest setting... no problem doing with an 88mm turbo and my 48mm WG.
But usually you can only go to 3 X's the spring rate for MAX boost..... like i know its true on mine an di cant go over 21 psi with the spring thats in there now....
Swapped out to a larger spring for the track.
Kyle
