D1SC or OFI? What would you go with?
If I wanted a nice reliable true street car that I would drive and park and drive and park daily, I would buy a D1sc, put the boost around 12psi, tune it and forget about it.
Might possible do the same with an APS twin turbo system if it's as nice as the Vett system/old Incon system...but it's not available.
If I wanted something to keep tinkering with to go faster and faster I'd buy a turbo set-up from OFI, or others......which I'm hacking on today.
Then again, ya look at Kevin running 149.xx with a sc and go Hmmmmmmmmmmmm.
The turbo systems are driven by exhaust velocity and exhaust heat.
There is less parasitic losses with a well designed turbo system, but there are very few good turbo systems on the market.
The OEM companies spend millions of dollars in R&D, where aftermarket companies largely rely on their customers for a lot of the R&D. Meaning, their kits get out on the market, and if problems are found, parts are redesigned. This method of R&D can work just fine if past customers kits are updated, and the companies stay in business. This last part, staying in business, has been a huge problem with most turbo companies. ATI ProCharger has been in business for over eleven years, and their kits have been redesigned and improved upon along the way. No turbo companies producing kits for our cars have been producing these kits for any length of time.
In my opinion there is a greater chance of turbo kits having some of their more expensive parts failing, due to the extreme heat cycles these parts endure. Turbo mounts fail, exhaust castings develop cracks, etc. Bob
I had a turbo, if I would do it all over again, Id get a D1SC.
Edit: Given the choices, I voted Procharger for proven performance. No offense to OFI, but I can't afford to pioneer a new kit.
BOSS APPROVED!
