fuel system question please
Old Feb 26, 2007 | 03:39 PM
seadoo's Avatar
Default fuel system question please
what fuel pump would be needed to run 12-18lbs of boost?? (i plan on starting at 7lbs, but dont want to buy everything again when i up it.
also, what size injectors do you recommend.
thanks guys
Old Feb 26, 2007 | 03:49 PM
SSilverSSurfer's Avatar
run a couple 255lph with a hobbs switch
Old Feb 26, 2007 | 03:52 PM
lmt0705's Avatar
I did a dual 255, but what is a hobbs switch, should I be adding it?
Old Feb 26, 2007 | 04:09 PM
the hobbs switch will just kick on the 2nd pump at a certain psi, not necessary but convenient, alot of people run it
