budget single turbo build
on another topic IF i went twin could 2 16g or 20g turbo be enough to achieve me objective? simple yes or no if no how small of turbo(s) could i run. i know the incon tt kit runs like t2528 but not sure how small those are.
You will have TONS or troubles and headaches! Why not buy an STS kit have everything you need already and be done. You said yourself you have $4000 to spend....buy a used kit and still have $1000-1500 left over!
Little things add up quick! like clamps and hoses...trust me....ask anyone...and they will tell you they spent ALOT more than they expected!!
oh and a twin setup to be safe and reliable I would be looking into spending about $5000-$8000
If I was your I would save the money for an STS kit if you have your mind set on a turbo...cause in my opinion if you go cheap you will end up spending more money than you would if you just bought a kit to begin with..
If you plan on doing a single I would go T67 with what you have in mind...IMO the T60 seems to be a little small for our motors...but some have had good success with them...
Turbos: Garrett, Turbonetics, Precision those are some good companys that I would go with.
http://cgi.ebay.com/ebaymotors/TURBO...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/OBX-H...QQcmdZViewItem
im looking to run like 5lbs of boost
I built a 84 300zx out of a strange pile of parts injectors for a Mercedes,air flow meter from a 93 cobra, fuel pump from a 90 300zxTT, spearco IC, garret/actuater wastegate T3/T4, HKS BOV,electronic boost and waste gate controller other little stuff.
the motor is 3 litre the T3/T4 made it a very stronge car 16PSI pump gas =360RWHP, 22PSI 105 octane = 450RWHP both on cool days.
That being said two T3/T4 s would provide plently of boost for a 5.7 litre motor. and being small will spool very quick and a good electronic boost controller will make them spool even quicker.
Search the rice sites and get a good brand name turbo.
the 300zx sites will be good for a regular T3 then add a T4 compressor it may take time to accumulate all nessary parts.
I agree buying a complete kit is easy but closetly takes out the fun of it and you look like everyone else.
Good luck and have fun w/ the friends that are helping.
