Master pro turbos
Old Feb 28, 2007 | 04:18 PM
onemeanls1z28's Avatar
Default Master pro turbos
i was wondering if anyone has ever used the master pro t70 .68 a/r turbo. i am building either a rear mount or a front mount setup (i havent decided yet) but i need to know if the turbo is a good quality turbo.
Old Feb 28, 2007 | 04:22 PM
6techniques's Avatar
Do you mean Master Power? If so man, you should really do a search on that one...Good quality??? I havent personally ran one but there a quite a few horror stories floating arount on the web. Also check out the Turbomustangs site as there is a big thread over there on MP turbo failures.
But at the same time, there are guys out there doing ok with one...I suggest doing some more searching on the matter and then coming to your own conclusion.
Edit: here is a poll to get you started.
http://www.turbomustangs.com/smf/ind...?topic=74174.0
Old Feb 28, 2007 | 07:47 PM
99Z28LS1's Avatar
master power makes good turbos from what i have seen, i havent seen anyone bashing them so i guess it means they are ok
Old Feb 28, 2007 | 08:22 PM
will62085's Avatar
after builing no boost, and making funny noises, i pulled my air filters to find wheel to housing contact, bearings are shot to hell on both turbos....and all after 1200miles
