Eboost2 hookup question
Old Mar 3, 2007 | 06:33 AM
DanaliHD's Avatar
Default Eboost2 hookup question
my eboost2 instructions say port1 should be hooked up the a boost source before the throttle body and NOT to the intake manifold. Mine was hooked up by a former sponsor to the intake manifold. Was he wrong in doing so? Should I move it? Where would i put it otherwise?
I'm using a progate along with it and the 2 hoses to the progate are hooked up properly.
Old Mar 3, 2007 | 09:02 AM
MIGHTYMOUSE's Avatar
there are two ways to hook it up per the instructions that i do not have handy. they may have it the other way
make sure it is set up one of the ways in the instructions, otherwise it is wrong.
Old Mar 3, 2007 | 09:20 AM
DanaliHD's Avatar
if i just shut the eboost2 off i'll be running off the wastegate right? sound reasonable?
Old Mar 3, 2007 | 01:07 PM
if it is hooked up per directions it should run on wastegate pressure when off
Old Mar 3, 2007 | 03:20 PM
DanaliHD's Avatar
Ok, i shut it off. truck still idles like *** crack. I'm assuming I have a vacuum leak somewhere since my vacuum reads a max of -15 at idle and the truck almost stalls when i put it in gear. I thought the eboost was causing this but clearly not.
