Turbo frame question
Old Mar 8, 2007 | 12:09 AM
LSONE's Avatar
Default Turbo frame question
I'll use a t-76 gtq as my example for this question. What type of designation is used to describe the physical "size" of the turbo (ie exterior dimensions)? Also, what is the 76mm the largest size they make for the frame? (I hope my terminology is correct. )
Old Mar 8, 2007 | 12:15 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Its considered a small frame turbo. As for the largest true 76mm unit. Well that would probably be the S76, which is a mid-frame unit.
Old Mar 8, 2007 | 01:04 AM
LSONE's Avatar
Er, I worded the last question poorly. What is the largest (in wheel size) "small frame" turbo? And thanks alot for the info
