Newbee at Turbos. Will this work?
Old Mar 12, 2007 | 07:08 PM
Shoulder Shaker's Avatar
Default Newbee at Turbos. Will this work?
Well I have taken the plunge into the FI world and now I have questions. I have a 408 Iron block that I'm putting a S85 OFI turbo kit on. I have run into a little problem with money so my questions are;
1. Will a set of stock 6.0 liter heads work on my car? Will I have to change the springs or anything?
2. Does anyone have an idea of what size cam I should run? I will have the LS6 intake and stock trottle body. I will be going with a Versa Fueler and 96lbs injectors. This will be through a M-6 and 10bolt for now. What type of power will this set up make?
Any help would be greatly apprecieated. I did all the searching that I can do and sometimes it helped and other times the search didn't work (lol)
Thanks again.
Old Mar 12, 2007 | 07:24 PM
Juiced's Avatar
maybe you should save your money for a rear end, that 10bolt is not going to like the tq of a 85mm and 408.........
Old Mar 12, 2007 | 07:32 PM
black98ws6ta's Avatar
A set of stock 6.0l's will work fine, but you will need a mininum of comp 918 springs. If you do a cam depending on the lift it would be smart to do a set of patriot dual springs.
Cam size will depend on what your looking for out of the car. Here is a good guide on cam choice for a turbo application.
http://www.forcedinductions.com/help.htm
Old Mar 12, 2007 | 08:02 PM
LOL yeah that was the plan but as I stated I had a family emergency that just about drained the funding for this project. I just want to get this thing going instead of setting out the whole season.
Old Mar 12, 2007 | 08:03 PM
Ok cool. Is that the only thing that will need to be changed in the heads or will the seats and all that other stuff need to be changed as well?
