67 TT camaro Build
Old Mar 14, 2007 | 09:18 AM
RealQuick's Avatar
Default 67 TT camaro Build
I am fabbing the hotparts for my friend's TT 67 Camaro build. He currently has a 355ci setup. I think he has Brodix heads and a 22x duration cam and is around 10-10.5:1 CR. He has a Richmond 6 speed. He has a fully forged 383 with 8.5:1 CR with Dart Pro 1 Heads (230cc) that he will use after we pop the 355ci. Here is the turbo combo (will run on 6-8psi for awhile):
Two MasterPower 60-1's
Two Tial 44mm Wastegates that dump into the DP's
True tubular 1 5/8" headers with 1/2" flanges, 2.5" collector, T4 flange
3" DP's that connect to an H-pipe (currently on the car)
We'll throw in 1 O2 bung on each DP for tuning (incase he goes EFI down the road)
All hotparts will be coated 16 ga mild steel. Figured I'd share some pics to show where I am at:
Old Mar 14, 2007 | 11:00 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Seems interesting. What was the logic behind going with those turbos? They seem that they might be a little small depending on how high you plan on pushing it.
Your fab work is really nice though. Have you tested to make sure everything will fit, that would suck?
Old Mar 14, 2007 | 11:07 AM
RealQuick's Avatar
The are T4 T60 turbos (support 750 flywheel hp each), they can easily support 50-60lbs/min each, and his motor will only demand ~75lbs/min total. Should be plenty for smeone who wants to make 600-700rwhp.
I am tacking the tubes together as you see it, tomorrow night I am going to his house for thetest fit. Thanks for the words.
