Please help can't pass emissions in colorado?
Old Mar 14, 2007 | 08:34 PM
bob19's Avatar
Default Please help can't pass emissions in colorado?
I have a 1999 camaro ss with a D1S-c running 9lb on 42lb injectors and it is emissions time and i don't know what to do if anyone could help that would be great it.Any sugggestions anything just want to get back on the road.
Old Mar 14, 2007 | 11:02 PM
Turbo Tech's Avatar
What type of testing do they do there, Is ia a tail pipe or pcm scan?
Old Mar 14, 2007 | 11:10 PM
HUNTER02SS's Avatar
If it just a pcm scan then as long as you do not have any code's or the ses light is on you should be fine.
Old Mar 14, 2007 | 11:40 PM
FieroZ34's Avatar
It consists of a visual and a tailpipe.
Make a friend at the local Jiffy Lube, and buy him some beer. That's how I pass it.
Old Mar 14, 2007 | 11:42 PM
redlineperformance's Avatar
Not sure how it is in Colorado but here in upstate NY they do a PCM scan the looks for MIL light and looks for run completion of emissions "monitors". NY allows a certain amount of monitors not to have run depending on the year of the car. These things take drive time and certain conditions to be met before they will be run by the PCM and passed. So, if you have reset the PCM with a scan tool or done a battery disconnect or a download the emissions computer will fail your car.
Old Mar 15, 2007 | 10:14 AM
618HAWK's Avatar
where in CO are you?
Most do the full load dyno test, with the PCM connected, along with visual.
Old Mar 15, 2007 | 10:33 AM
DanWS6's Avatar
Some counties in Colorado no longer require emissions testing.
Old Mar 15, 2007 | 10:38 AM
Kelly.'s Avatar
pm sent
Old Mar 15, 2007 | 06:10 PM
bob19's Avatar
I'm in aurora 618hawk is right thats what they do and i failed . Did you pass hawk. If so how did you do it .
Old Mar 15, 2007 | 06:22 PM
01ramair500hp's Avatar
im so glad we dont have to do that here.. it sounds like a pain
