wastegate pressure connection
Old Mar 15, 2007 | 11:42 AM
1a-play's Avatar
Default wastegate pressure connection
where on the intake is the best place to tap on the tubing for gauges/wastegate connections?
Old Mar 15, 2007 | 11:50 AM
MIGHTYMOUSE's Avatar
this is what i did
my WG however connects to a fitting on the turbo housing itself.
Old Mar 15, 2007 | 02:44 PM
1a-play's Avatar
thanks Dave- so what do you have connected there?
Old Mar 15, 2007 | 04:09 PM
on that port on the intake i have my boost controller, my fuel pressure regulator, my vacuum modulator for the trans, and one port on the blow off valve
on the turbo i have the wastegate, another bov connection, and the boost controller solenoid ports
and i have another port here where i hook up my map sensor
