Is my vacum low?
Old Mar 16, 2007 | 10:26 AM
JD_Z28's Avatar
Default Is my vacum low?
I have a built LS1 with an STS kit running 10.5psi. My vacum is at 10 and I wasn't sure if that was considered low for a 8.9 compression motor. Whats everyone else getting on their low comp motors?
Old Mar 16, 2007 | 11:58 AM
Superman09's Avatar
LS1Tech Sponsor
I think a lot of variables effect how much vacuum you pull at idle. I know cam/idle speed etc greatly effect it. I am on stock cam, etc so i idle at only 500 rpm and pull 24", but i assume you have a different cam and higher idle so i dont think 10's too bad. Again, many factors contribute.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Mar 16, 2007 | 12:23 PM
JD_Z28's Avatar
You're right. The cam plays a big part in vacum. I'm running a 224 224 on a 114 LSA about 600 lift.
Old Mar 16, 2007 | 03:38 PM
RooRnZ28's Avatar
my vacuum is at like 20-24 at idle
Old Mar 16, 2007 | 04:30 PM
ty_ty13's Avatar
7 Second Club
i have a 224/236 114lsa in a 408 and idles at 850ish and pull about 18-22''
