Supercharger HELP!!!
Old Mar 16, 2007 | 03:24 PM
RonniesLS1's Avatar
Exclamation Supercharger HELP!!!
Ok I want to supercharge or turbo my 01' formula but have a couple of questions.
First which is better a supercharger or turbo?
Can I turbo/supercharge a stock LS1 without anything or what do I have to upgrade?
Any suggestions on brands or models of supercharger/turbo?
Thanks!
Old Mar 16, 2007 | 03:30 PM
mattraypharbor's Avatar
lots of CASH!
Old Mar 16, 2007 | 03:49 PM
MaDMaX350's Avatar
if you are running a high boost setup you will defiantly need to do engine upgrades. as far as turbo or supercharger goes that is a matter of preference. most supercharges will make a lot of power and torque low in the rpms, as compared to a turbo in the high rpms. a supercharger will be a lot easier to install because you do not need turbo exhaust manifolds but a turbo setup has a bit more potential in the long run over a supercharger.
Old Mar 16, 2007 | 03:58 PM
NoGamesLS1's Avatar
Call procharger
Old Mar 16, 2007 | 04:00 PM
Beast96Z's Avatar
You should try the forced induction section.
Old Mar 16, 2007 | 07:04 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Click this link...it has all the information you need:
https://ls1tech.com/forums/search.php
Old Mar 16, 2007 | 07:46 PM
1997bird's Avatar
I would split the differance and call Wheel to Wheel & get a Rotex supercharger set up. Then you have a supercharger with the efficency & impeller speeds of a turbo. This is with a ROTEX and ROTEX brand only!!
