How will big cam respond to boost?
Old Mar 24, 2007 | 02:36 PM
  #61
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Think it out a little bit....
230/230//111 vs 230/230/114... (hugely generalized since cams will vary even between two different cams with the same duration)
Do you honestly expect the second cam will make a ton more power up top, and that the car with the 114 will best the 111 car? That's too big of a generalization.
I think the 114 car will have a higher peak, maybe 20rwhp (generalization), but the 111 car could be faster simply because the 114 car might have to spin a little higher to run the same.
best power band + best power under the curve + best shift recovery = fastest car.
Old Mar 24, 2007 | 04:32 PM
  #62
SVC707's Avatar
i personally was reading this thread but got tired of reading the whole thing, here is what i have to offer.....
a pretty common built 408 iron block AFR 225's , built by LME... and running a procharger D kit, nasty fuel setup. i am running the regular 4" pulley with i believe a 7 3/4 crank pulley. through moser 9" trutrac w/ 3.70's
Now im finally taking it back to synergy motorsports this monday for all out WOT runs. I will be sure to post my numbers.
the cam specs are 244/253 .6xx 115 lsa
Old Mar 25, 2007 | 10:35 AM
  #63
LS1Tech Co-Founder
Should make nice numbers on low boost since you have a big pump (engine).
Old Mar 25, 2007 | 11:41 AM
  #64
qqwqeqwrqwqtq's Avatar
Well, supercharger cams aren't at all comparable to turbo cams, but it will be interesting to see your results.
Old Mar 26, 2007 | 05:28 PM
  #65
SVC707's Avatar
he suggested and i agreed no need to push it to the limits if i want more i can pulley down the blower. right now only running 9.29 lbs of boost
