thick gaskets
Old Mar 20, 2007 | 07:13 PM
whitedevilWS6's Avatar
Default thick gaskets
hi i'm pretty new to the LS1 world and was thinking of running low boost on my motor (8 psi max). i don't want to get crazy with my car and dump a ton of money into it, so i was thinking of just using thicker head gaskets. how much would it lower compression? would it be safe up to 8 psi? what kind of modifications to valvetrain does it require to keep everything in check? any help would be appreciated thanks.
Old Mar 20, 2007 | 08:27 PM
NA$TY-TA's Avatar
I wouldnt use thicker head gaskets as a way of lowering compression.....
Stick with less then 8 psi on a stock motor and if it has ALOT of miles id do less then that and always save for a new motor sooner or later.... and FI is hard on a motor.
The smartest thing you can do is price everything you will need out on paper to see the total 1st and then sit back... FI isnt cheap at all.
Fuel parts, Tuning/Tuner, Kit itself, gauges , drivetrain and tires
Your new found power is going to be very hard on those last 2.
Kyle
Old Mar 25, 2007 | 05:59 AM
SStolen's Avatar
6.0L heads will lower your compression a full half point I believe.
Old Mar 25, 2007 | 06:17 AM
ss1129's Avatar
Are you refering to 243 heads? If so I thought those brought CR up?
Old Mar 25, 2007 | 08:08 PM
NA$TY-TA's Avatar
No hes reffering to the the 6.0 L heads like he said.. 317 castings.....
Old Mar 25, 2007 | 09:12 PM
Tom@SpeedInc's Avatar
Considering we install prochargers on LS2 C6s and GTOs with nearly 11:1 compression, IMO a couple psi from a P1SC and a dyno tune gives reliable power from a stock motor.
