10.75 CR safe for 5 pounds???
Old Mar 21, 2007 | 03:00 PM
Cchris1109's Avatar
Default 10.75 CR safe for 5 pounds???
I am installing a vortech v9 with aftercooler soon and i have the TSP 5.3L heads, my CR is 10.75
should i sell my heads/put on the stockers or leave it alone??
Old Mar 21, 2007 | 03:23 PM
Dragframe's Avatar
get 6.0 heads and run more boost =]
Old Mar 21, 2007 | 03:30 PM
SSilverSSurfer's Avatar
that would be a decent solution
Old Mar 21, 2007 | 04:45 PM
LS1injection's Avatar
Concider a Progressive Methanol injection system first
At 10.75 to one compression running 5 PSI you will be ok , but you WILL need to cool down that 5psi intake charge and boost up your octang level. Methanol will do all of this
I think at 5psi you will pick up some nice power , i wouldnt push it past 6 psi ,
With the methanol injection it will be awasome!
