Pushin water
Old Mar 21, 2007 | 08:57 PM
52172's Avatar
Default Pushin water
Should it even be a concern with 650 rwhp and a great safe street tune? I have ARP head studs not the oversize ones. Not exactly sure what head gasket just know it is slightly thicker than stock. Thanks!
Old Mar 21, 2007 | 09:13 PM
Snyper's Avatar
with a stock motor? yes you should be.
Old Mar 21, 2007 | 10:14 PM
52172's Avatar
check sig it will answer your question
Old Mar 21, 2007 | 11:37 PM
Frost's Avatar
I made 590RWHP at 10psi, stupid rich, and run 15-16psi on pump and meth on the street at about 18deg peak timing and like the 'spirited' driving I have ARP studs, MLS gaskets, TEA stage 2 heads, comp 228/228 116, but I'm at 8.5:1 static CR... I have had it up to 18 psi through 2-3 gears 8-9 times with good (leaded) fuel. I haven't pushed any water and it feels GOOD.
Old Mar 22, 2007 | 12:21 AM
SR-71 SS's Avatar
I am at 600 rwhp with cometic MLS gaskets and the arp studs, 15 pounds of boost and so far not pushing water
Old Mar 22, 2007 | 10:02 PM
427's Avatar
427
I have a little over 60,000 miles on my truck with 600 at the tires(4/AWD). I have had the heads off once about 20,000 ago and everything looked good. I use a factory MLS and stock bolts.
Kurt
