FMIC install
Old Mar 23, 2007 | 04:57 PM
CantKeepemhooked's Avatar
Default FMIC install
recently bought a STS remote mounted system and was wandering if this FMIC kit http://www.trtturbo.com/LS1FMIC.html is an easy install. it does with the STS system. but i was wandering what it takes to be installed before i buy this.(custom mounting? moving the radiator?)
Old Mar 23, 2007 | 05:15 PM
JD_Z28's Avatar
Everything is straight bolt in. The only custom work you'll have to do is cut the front bumber support and return pipe going to the intake manifold. I would also recomend cutting the front bumper open.
Old Mar 23, 2007 | 05:46 PM
trans2000am's Avatar
did mine a couple days ago not to bad,once you get started.
