BOV Before or after the I/C on high boost setup?
Old Mar 29, 2007 | 09:53 AM
NA$TY-TA's Avatar
Mine if before the IC...... works fine for me......
Old Mar 29, 2007 | 10:59 AM
cablebandit's Avatar
Mike, good enuff for me...I will put mine wherever it fits
Old Mar 29, 2007 | 11:21 AM
1INSANEGTO's Avatar
Close to the TB
Old Mar 29, 2007 | 11:28 AM
ZL1Killa's Avatar
Originally Posted by lunati397
pressure is resistance to flow so the highest pressure point would be before the TB because that is the point where the flow is getting blocked off creating pressure at that point IMO i would have it closer to the TB that is where the spike will be seen first
I am a pneudralics specialist and that is no **** straight out of the book just changed it to a turbo setup as opposed to a shutoff valve
u da man! lol.
Old Mar 29, 2007 | 11:34 AM
89Formulaws6's Avatar
Originally Posted by 1INSANEGTO
Close to the TB
now thats amazing
tial bov looks like right?
Old Mar 29, 2007 | 11:46 AM
Red97Z's Avatar
Has anyone ever experimented with using a dual BOV setup? One setup in front of TB, another before the I/C perhaps and closer to the Blower? Just a thought, if the vacuum line was split with like a T fitting, then routed to each BOV, and assuming they had the same spring tension/make/model, they would release at the same time, with no leaking boost.
Old Mar 29, 2007 | 01:11 PM
1INSANEGTO's Avatar
Originally Posted by 89Formulaws6
now thats amazing
yup tial bov loudddddddddddd
Old Mar 29, 2007 | 01:13 PM
1INSANEGTO's Avatar
BTw this BOV is really cheap and works good on the 83MM car
http://www.siliconeintakes.com/categ...bba3a1efeaad60
Old Mar 29, 2007 | 03:05 PM
flippincamaro's Avatar
Mine is right after the turbo,
