Moved my turbo Formy...
Like Matt said before, I have to get heat into the turbo, and then make sure the turbo is boosting before I let go the brake/2 step. I was letting go before I went into boost.
These tires tuck under the top part of the TA's wheel well by about 1" and stick out 1.5-2" down at the point were the side skirts meet the body. They would not fit at all with non-adj LCA's. And by looking at it, the offset LCA's were a good idea because there's only like 3/4-1" between them and the tires.
Bogarts sit out a little more than a 15x10/7.5 ProStar, the same combo on a ProStar would require severe BFH'ing and more cutting. I do have my bump stops cut off.
I hear ya on that...... mine is tight... i guess thats what makes it so streetable also.....
Im not going to worry about that right now.....
Just like PSJ is saying..... were both going to get more seat time with the TB and 2 step and im sure from there both of us will keep getting faster and faster with the same boost setting each time......
Then it will be time to up the boost....
Kyle
Stall speed off boost is not a good indicator.
A converter that couples HARD when it's suppose to, and has the proper shift extention isn't based on stall speed alone. Let the thing use the torque it's making.
Does no one test a combo before throwing parts at it anymore??
I hear ya thats why im taking your advice........esp. since youve been faster then me in it LOL
and the fact you know more them me LOL Stall speed off boost is not a good indicator.
I'm fine with my converter and don't plan to change it out. I was mainly just questioning how you all are footbraking the car with the converter being tight when there is no boost on it.
Kyle
It drives awsome on the street....
At cruise on the freeway @ 55-60 MPH im usually between 125-150.
Its a lil warmer in stop and go rush hour traffic
Thats about 150-185..... then when she's back up to speed on the freeway she drops pretty quick back to between 125-150.....Kyle
