Turbo Heat issues
Old Apr 1, 2007 | 09:14 PM
02SSLE's Avatar
Default Turbo Heat issues
Hey guys I know I am not the only one with this problem. I have had trouble with the rubber in the steering shaft that connects the steering wheel and rack from melting. the shaft has rubber to insulate it to obsorb vibration. I keep melting it with DP it is about a 1/4 inch away. Is there anything I can wrap around it? Some kind of heat sheild or boot, heat wrap?
Old Apr 1, 2007 | 09:48 PM
Country Boy's Avatar
Senior Member
yep... I melted mine. Get a new shaft and wrap it with the heat reflective wrap. It comes in a sheet. Wrap it from the top to the bottom, even over the u-joint.
Old Apr 1, 2007 | 11:13 PM
otherwhitemeat's Avatar
get rid of it and weld it up
Old Apr 2, 2007 | 11:27 AM
RW99's Avatar
Which kit/downpipe?
