LS6 Head and Cam and Vortech V9 Kit?
Old Apr 6, 2007 | 10:57 PM
slow_ws6's Avatar
Default LS6 Head and Cam and Vortech V9 Kit?
I have already purchased the GMPP LS1 to LS6 Conversion Kit! I was also thinking about adding a Vortech V9 Supercharger Kit!! Would the two be a good combination??? How much rwhp could i expect and wat kind of 1/4 mile times can i expect?? Also would the car run better with the factory 3.23 gears or with some 3.73s??
Old Apr 6, 2007 | 11:08 PM
todd4168's Avatar
around 550 I would guess.
Old Apr 6, 2007 | 11:22 PM
slow_ws6's Avatar
Would the car be very streetable?? And would that much hp be ok withe the engine internals being stock? or would i have to look into getting a new engine soon?
Old Apr 6, 2007 | 11:50 PM
1badsupersport's Avatar
That head and cam combination is going to raise your compression some too; which is not necesarily a good thing with supercharged motors. A set of 6.0 heads and a nice split duration cam would be a much better combination for the setup that you want. Also, stay away from 373s and 410s as you would run out a gear really fast in a supercharged car. As for vortec they make a great kit, but know what you are getting and you should be fine. Best of luck on your setup.
Old Apr 7, 2007 | 12:13 AM
slow_ws6's Avatar
ok thanks guys!!! Do u think if i put a 150-175hp TNT nitrous kit it would be able to outrun it if it was supercharged on the street and at the track?
