When are the IATs to high for FI??
Old Apr 20, 2007 | 04:28 PM
ABeasst's Avatar
Default When are the IATs to high for FI??
At what point should you start to worry about how high the IATs are? What range of IATs do you guys run in??
Old Apr 20, 2007 | 05:10 PM
onfire's Avatar
Coal Mining Director
Great question.....hard to answer. Need more octane to "help" offset high AIT's. Combo related also....different combos will tolerate different temps. For me 170 was the cutoff, then I went to meth and dropped it down since the turbos were killing the IC's.
Old Apr 20, 2007 | 06:25 PM
DrTurbo's Avatar
LS1TECH Sponsor
200 is what Jose considers max on a gas engine and 400 on a diesel.
Old Apr 20, 2007 | 06:44 PM
HUGGER ORANGE SS's Avatar
Yes great question...
My IAT's jump up a good 70 deg above Amb temps with a good 10 second pull with 15psi of boost from my 3" twin intercoolers from ATI... These things hardly do anything at 700rwhp..
Now I have meth, I know it helps as I get no KR and the car runs smoother. No dyno numbers yet and dont know how much the meth helps with the IAT's as my sensor is before the meth spray..
Hope this help..
Clint
Old Apr 20, 2007 | 09:03 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Kurt @ W2W told me that IAT's over 150F trouble him.
Old Apr 20, 2007 | 09:08 PM
Zombie's Avatar
I don't like anything over 150.
Meth fixes that though. I can see an initial temp drop of 60 degrees and always ends up below ambient. The hotter it is the better the meth cools.
Old Apr 21, 2007 | 04:41 AM
EPP's Avatar
EPP
Smile
Hope this help..
Clint
Clint, you should jump up to the thicker 4.5" intercoolers.
From an article that was in a GM Hi Tech magazine. Bob
"Ryan compiled the raw data into these convenient graphs and as you can see there was approximately .5 psi less of boost drop off from the larger intercoolers. In addition the larger intercoolers were 10 percent more effective in cooling the intake air temperature, especially in the upper rpm range.... "
"...At 6500 rpm intake air temperatures were only 62 degrees with the 4.5-inch intercoolers, meanwhile, with the smaller units, intake air was at 71 degrees. As you can see from the graph, as rpm and boost increased so did the disparity between the two intercoolers, proving the potential with higher boost levels."
Old Apr 21, 2007 | 09:35 AM
smokinHawk's Avatar
on my old turbotech street kit with the intercooler near the radiator my IATs got up to 200* on a 100* day, that bothered me, i would like to see them no higher then 170* on a very hot day, but would prefer the low 150 range at that ambient
Old Apr 21, 2007 | 09:42 AM
T/A KID's Avatar
This may sound really stupid put how are you guys measuring your IAT's???
I am doing a 4inch thick OBX intercooler on a Open front Bumper pushing roughly 650-700RWHP on a D1SC (15lbs or so) and I am wondering what my IAT's would be?
Old Apr 21, 2007 | 10:07 AM
kp's Avatar
kp
Logging the IAT sensor is a good start
Mine will get up to 150 on a 90 degree day at the end of the 1/4 with the 4" OBX and D1SC, thats the highest I have seen. Pretty much it will always rise 40-45 degrees on a pass, if I leave the line at 75 it will go to 115, 110 and it will go up to 150 etc. Thats acceptable to me.
Old Apr 21, 2007 | 10:37 AM
xxxhp's Avatar
I got this from my scanner log. Running my current setup (in sig), 12 psi and 10 seconds of WOT time would increase the IAT by 38F.
I would start to worry at 150+, and I would stop at 170
Old Apr 21, 2007 | 12:13 PM
Frost's Avatar
Don't know if you have meth or not, but if you don't check out this post I made with screen shots of logs pre and post meth.... IATs below ambient after meth and 7 degrees of timing is night and day on an FI car.. https://ls1tech.com/forums/showpost....3&postcount=35
Old Apr 21, 2007 | 12:18 PM
Thx BOB... Naw I'm planning on just going to a Front Mount... I've seen you're kit, it's very nice, but I'm thinking I would like to to my own with a single inlet/Duel outlet for the intercooler so I can have the piping Y in just brfore the TB. Kinda like Imtimadat8 97 LT1 setup.. I think that would look great under my hood.. + a 10% better difference on the 4.5 intercoolers, just not good enough compared to a front mount..
CLint
Old Apr 21, 2007 | 04:06 PM
Schantin's Avatar
On "stock" tune the PCM will begin pulling timing as low as 100 degrees. I was seeing 130-135 on my STS at 5PSI before adding an intercooler. After the FMIC, the highest I've noted is 105. That was during some non-stop full boost runs over a period of 20 minutes.
I set the parameters on the PCM to aviod retarding timing until 110 degrees. High boost will create more heat, but even so I'd call anything above 130 a bad thing. Just my $0.02
Old Apr 22, 2007 | 03:08 AM
Tirefire's Avatar
Would a scanmaster be a good way to measure IAT's?
