Compressor A/R
Old Apr 29, 2007 | 10:47 PM
Goldstreak65's Avatar
Default Compressor A/R
So if Turbine A/R contributes to Spool rate,What exactly does compressor A/R control?
ta02zx10r's Avatar
cfm and boost
Old Apr 30, 2007 | 06:43 AM
I need a little more than that. How does cfm and boost relate to A/R?
Old Apr 30, 2007 | 10:12 AM
DrTurbo's Avatar
LS1TECH Sponsor
Compressor A/R controls compressor outlet velocity and map movement. You can shift the map a little with different covers.
Old Apr 30, 2007 | 10:19 AM
So holding the compressor wheel size constant, a larger size compressor A/R shifts the map left or right?
Old Apr 30, 2007 | 11:07 AM
DrTurbo's Avatar
LS1TECH Sponsor
To the right, but could have adverse effects on surge limits and compressor wheel stagnation under higher pressure ratios.
