OFI--need my a/c stuff
Old May 5, 2007 | 11:03 AM
HUNTER02SS's Avatar
Originally Posted by cablebandit
i stayed at Gregs....we are going in a bit to get an alternator. Ed gave me the combination to get into the track
The track all to yourself,Damn that must be fun!Hope you get the problem's fixed.These are great time's you are running!
Old May 5, 2007 | 02:55 PM
Superado's Avatar
11 Second Truck Club
Jerry...any word?
I tried calling yo' monkey *** when I left the sto'!
Holla!
Old May 5, 2007 | 03:51 PM
cablebandit's Avatar
just got home...it was the wire...i broke it taking the alternator out. it is fine now
My phone was almost dead when you called and i wanted to save my battery just in case!! call ya in a bit!!
Old May 5, 2007 | 11:03 PM
1INSANEGTO's Avatar
I have been waiting for like 9 months for my damn filter for the turbo. Good luck! I do not plan to ever see them
Old May 6, 2007 | 10:45 AM
b1er's Avatar
Originally Posted by tt427ls1
I am taking care of it and you all will have a/c that order a complete kit.
This is what bugs me.....from this statement it would seem Jerry's **** out of luck....everyone that ordered hot parts and a radiator are screwed....anyone else see it this way?
I certianly hope this isn't the case....
Old May 6, 2007 | 01:31 PM
Brains's Avatar
Sounds like I might be screwed too. or at least fab up a bunch of **** myself I ordered the kit thinking it would fit with A/C, but it sounds like that isn't the case. Where are there problems?
Old May 6, 2007 | 03:48 PM
Joel is working on a new condenser and hoses ...call him Tuesday and see where he is at
Old May 7, 2007 | 03:35 PM
obZidian's Avatar
instead of ranting and adding negativity to the post, why dont you not say anything?!
You got your parts, after threatening that you wanted your money back, blah blah blah blah!! then you sold it, hmmm.... now your "buddy" has a single turbo kit identicals to joels.. come on dude, honestly, just stay out of it if your just gonna add negative vibes to the thread..
Old May 7, 2007 | 03:49 PM
Brains's Avatar
Hmmm... Well, I only ordered the hot parts, figuring I could somewhat easily replace the existing log kit and just tweak the existing cold side to fit. Maybe I should have thought through this a little more, looking at the list of things Joel includes in his kit that I didn't buy from him. If nothing else, the OFI hot parts will work great on my Mustang -- I have PLENTY of room in that car and won't need the custom radiator or A/C condenser. Then I'll find another solution for ZAngel's car where we can reuse or at least not replace as much existing stuff.
The whole idea started out as a way to solve the cracking manifold problem she has whenever she actually gets on her car a little hard.
As an aside, I hold nothing against Joel or OFI, as his kit appears to include or will include everything needed. It's my issue that I didn't get a complete kit, nor did I do the proper research to see so much else needed to be changed to accommodate the kit.
Old May 8, 2007 | 12:54 PM
1INSANEGTO's Avatar
Yeah I got my parts and they were nothing but a big pile of crap the other gto owner can tell you hell he spent $1200.00 to fix all of the crap. My down pipe would not seal correctly my cross over tube would not fit correct and will have to be redone, the header flanges were warped. Thickness of the mat vs cost is crap. Need I go on? I can all day long.
BTW I did not sell it I am having the issues fixed.
To top all this off I had to buy a new radaitor mod the fan shroud, transmission lines etc. The whole intercooler piping had to be reworked.
Old May 8, 2007 | 01:26 PM
SSblack98's Avatar
Yeah like I've said before Joels ideas are great but the actual fitment of most of the kit leaves much to be desired. I think if you are going to build a kit with everything that tight, it needs to be done ON THE CAR and fit to each individual car. Unfortunately if you don't have a welder, acetalyne torch, hammers etc, you will have a great deal of difficulty installing these kits! Even with those tools it was more time-consuming then I had thought possible in my wildest dreams. I did receive my new pass header so hopefully actually have it running soon!!! Will hope to post up something positive in the way of great dyno/track numbers soon!!!
JOEL I STILL NEED RADIATOR HOSES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 8, 2007 | 02:53 PM
  #32
My hot parts fit my car very well...no complaints there....just need a/c....anyone get a timetable from Joel? I got 2 weeks...2.5 weeks ago which is why i posted.
I noticed that if you bolt up the wastegate but not totally tighten it down...you can then move the dp around a little to give you more clearance around the steering shaft and alternator.
