want firebird fmic pics
Old May 11, 2007 | 04:04 PM
smokin2001formula's Avatar
Default want firebird fmic pics
I did try search and it came up with a message 503 service not available. How is the bird filler panel attached to the bumper? What mods would have to be made to have a working a/a fmic? I took a look at mine an there seems to be space in between it and a backing of some sort. Any help or pics of guys running front mounts with their birds would be appreciated.
Old May 12, 2007 | 12:33 AM
JAvenger007's Avatar
I would just wait for the search to return. There is one of these threads started once a week....and of course the same old pictures get posted again...and again....and again....and again.
What do you need a FMIC for?
Old May 12, 2007 | 09:44 AM
Got a turbo kit going on the car.
Old May 12, 2007 | 09:50 AM
Superman09's Avatar
LS1Tech Sponsor
Bird filler is just attached by a few screws in the open area around the plate. Just remove it there.. Then that area behind it needs to be cut out. No mods really to get the FMIC itself to work, just get it bolted up and have air flowing to it. You might have to lose the foglights depending on side of FMIC and where you mount it or brackets could be made. Hope this helps...
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old May 12, 2007 | 09:54 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have many pics of my SC FMIC setup:
http://psj.ls1tech.com/gallery/main....&g2_itemId=304
Old May 12, 2007 | 10:08 AM
Thanks guys I was hoping someone would chime in with some useful info. For some reason the search still isn't working for me says something about a error message 503. Responses are very much appreciated.
Old May 13, 2007 | 10:07 PM
crazy search.
You can do it a couple different ways.
"Speed" on these boards made a puller fan setup that mounts onto the IC and then its mounted perpendicular to the radiator in that opening behind the bumper.
https://ls1tech.com/forums/showthrea...highlight=FMIC
