Bore + stroke + Boost = ?????
Old May 15, 2007 | 12:20 AM
lsanb05's Avatar
Default Bore + stroke + Boost = ?????
How much boost can an ls1 with a 4.1" stroke and a 4.030" bore which makes a 418 handle? im planning on doing a procharged d-1sc setup...????
Old May 15, 2007 | 11:36 AM
dschmittie1's Avatar
I think some of that depends on what Parts you are using in the bottum end, and how the rest of the motor is put together. It should handle enuff to max out the D1 That motor might be a good canidate for an F1
Old May 15, 2007 | 12:01 PM
98turbls1's Avatar
I would definitely go with an F1 or greater because I think that 418 will use all of that blower up really quick...
