pease look inside
Old May 17, 2007 | 02:27 AM
turbo408stroker's Avatar
Default pease look inside
what does every one think about a ball bearing gt45 turbo what whould it make on a 408 stroker with built fuel system and a elky control meth injection
9.0:1 with 6.0l heads trying to hit 900hp
Old May 17, 2007 | 03:23 AM
venom ws7's Avatar
Check EPP there is T.A in customer section 900rwhp or close with same heads but not sure about the turbo size.
Hope it helped.
Old May 17, 2007 | 10:03 AM
RealQuick's Avatar
I dont think you can get a "gt45" in ball bearing form. Is this one found on ebay? If so, its probably jus a standard bearing. Also, a GT45 is a 68mm turbo... way too small for a 408ci... unless you are using 2 of them.
Old May 17, 2007 | 02:02 PM
a gt45 is a 83mm ball bearing turbo not a 68mm
Old May 17, 2007 | 02:11 PM
DrTurbo's Avatar
LS1TECH Sponsor
Depends on the manufacture. The MP GT45 is a 68mm journal bearing unit. The Garrett GT45 is a dual ball bearing and we offer it in several different compressor options.
Old May 17, 2007 | 02:12 PM
frcefed98's Avatar
No a GT45 has a 83mm hot side the compressor side is a 68mm.
Definately the wrong turbo for a 408ci.
Old May 17, 2007 | 02:13 PM
coop5885's Avatar
is it s T6 flange? Whats the going rate on them? and yuo take trade ins on a PT88 with 65 miles on it?
Old May 17, 2007 | 02:22 PM
DrTurbo's Avatar
LS1TECH Sponsor
PT88 is a better turbo for an LS1 monster, then the GT45 from Garrett. Its 12 blade turbine wheel doesn't flow as well as the TV style wheel, but it does spool fairly quick with the DBB and 83mm compressor wheel. Its a T4 as well, which does make it nice.
Old May 17, 2007 | 02:24 PM
RealQuick's Avatar
How much you looking to get for that T88? Shoot me a pm.
