STS guys spark plug gap
Old May 19, 2007 | 07:07 PM
vipvegas's Avatar
Default STS guys spark plug gap
I have an 01 WS6 with the stage 2 sts, fmic, running 8 psi, what are you guysgapping your plugs at .030 or .035?
Old May 19, 2007 | 07:08 PM
JAvenger007's Avatar
.035 gap
Old May 19, 2007 | 08:55 PM
hissin'98's Avatar
Anywhere from .30 to .35. If it starts to miss at rpm then tighten the gap a bit. I've never had a problem with it but have seen spark blowout on another turbo car and it sucks.
Old May 19, 2007 | 09:22 PM
99Z28LS1's Avatar
TRT did mine to .30
Old May 20, 2007 | 03:26 AM
enginjoe's Avatar
Ngk Tr6 .035
Old May 20, 2007 | 11:38 AM
pdanrichey's Avatar
.0301298347501129385893719849283761983625 here.
Zombie's Avatar
.025, I run higher boost than most STS guys though.
Old May 20, 2007 | 05:28 PM
vipvegas's Avatar
Zombie its Brennan you will be tuning my stuff will be done tonite and ready for the tune. We will be tuning for 7-8 psi. What do you think stay safe with .030?
Old May 20, 2007 | 08:24 PM
my STS manual says .035 FWIW. Not that it matters, because a lot of people adjust to their own setups
Old May 21, 2007 | 11:04 AM
Zombie's Avatar
.030 should be ok for that boost level. If it blows the spark it, just have to redo them.
BTW, don't run platinum plugs, run some NGK TR6's if you can find them, or another copper plug 1 heat range colder than stock.
Old May 21, 2007 | 12:32 PM
vipvegas's Avatar
I gapped them at .030 and they are tr6's. WIll do the fuel pump tonite, trap door style. When can you do the initial tune?
Old May 21, 2007 | 12:54 PM
ZL1Killa's Avatar
Originally Posted by JAvenger007
.035 gap
yes...thats what i use
ZL1Killa's Avatar
if you don't want to do the trap door... its really not hard to drop the tank out
Old May 21, 2007 | 03:07 PM
SonofaBish's Avatar
not to barge in on this, but what about using an irridium plug??
I'll be pushing about 700 to the wheels (under about 14 lbs boost), so i was looking to maybe go a little colder than a TR6, to a TR7... but they only make this in a irridium plug (or so says the book at the auto parts store) ... Or do i not need to go to a plug that cold?
Old May 21, 2007 | 03:10 PM
You do need a colder plug but theres a few different ones that people use. Do a search for TR plugs in that range, youll see tons of threads blabbering back and forth about them
Old May 22, 2007 | 09:55 AM
WS6Vixen's Avatar
If you ask the guys at STS they will say .028 to .030 for a gap. I have mine gapped at .029.
And from what I'm told, you can't gap irridium plugs. And if you can, you can't gap them to the gap needed for forced induction.
Old May 22, 2007 | 12:35 PM
SSnakekiller's Avatar
.030 to .035 is fine for normal boost.
.027 - .030 is better for boost+methanol.
Old May 23, 2007 | 10:36 AM
Silver02Z28's Avatar
I forgot to gap my plugs on my new setup. I was running NA for a while and recently went back to a turbo set-up. My plugs were gapped at .050 for NA, and I was getting major blow out under boost. I gapped them back to .030 and all is fine. I'll be replacing the old plugs with TR6s this weekend.
Old May 23, 2007 | 11:03 AM
Eatinstang4life's Avatar
I at first had mine gapped at .035 and it was backfireing, lowered down to about .030 still backfiring under boost not as bad now though, should I gap them closer?
Old May 23, 2007 | 03:57 PM
koolaid_kid's Avatar
I have always used 0.30 iridium (not 0301298347501129385893719849283761983625) with success.
