Does a fluid filled harmonic balancer stop false knock readings?
Old May 20, 2007 | 10:29 PM
FastKat's Avatar
Default Does a fluid filled harmonic balancer stop false knock readings?
Just as the title says... will a fluid filled harmonic balancer (rather than an elastomer balancer like the factory crank pulley) reduce or stop false knock readings on an FI car?
-Dave
Old May 21, 2007 | 01:16 AM
DeltaT's Avatar
No reason it should. IIRC, they damp motion over a certain rate of acceleration, not sound, and a knock sound (or false knock sound close enough to trigger KR) has a pretty distinctive hi-freq ring.
Jim
Old May 21, 2007 | 09:30 AM
FastKat's Avatar
Interesting.... I think someone on eBay was claiming that fluid filled dampers reduce false knock readings.
Old May 21, 2007 | 10:57 AM
Zombie's Avatar
Ebay sellers also say magnets improve your fuel milage...
Old May 21, 2007 | 11:13 AM
RW99's Avatar
Removing your knock sensors will help alleviate false knock.
Tune to the AFR and trust it. And have a wideband in the car.
Old May 21, 2007 | 01:27 PM
FastKat's Avatar
Yea, I know the eBay people make some wild "too good to be true" claims... that's why I checked here!
