Finally took it out to the track
Old May 23, 2007 | 11:34 PM
SVC707's Avatar
Default Finally took it out to the track
60': 2.089
330: 5.650
1/8: 8.337
mph: 95.35
1000: 10.569
1/4: 12.391
mph: 125.33
full street form STREET tires, subs and all
yes traction was a bitch, but i wanted to see what street potentials i had on regular non drag radials before slapping those on. i have couple vids taken but dont know how to transfer them yet to cpu.
i had posted up in the boosted section now that i have a time slip
here's my video. im determined to hit 11's on street tires but i think ima just run with the bfg drs next
Old May 23, 2007 | 11:47 PM
Josh@KY-Turbo's Avatar
You have the MPH. Now you need the traction to match up the ET. Nice work.
Old May 23, 2007 | 11:53 PM
SVC707's Avatar
my last run was all messed up too. car rolled and red lit... but i said f it and ran either way to see my mph's 96.68 and ended at 126.67 everything was smoother and i think i wouldve hit 11's on that run... needless to say i was pissed.. my goal was to hit 11's on street tires. this is my first time out to the track since 1997 too
bought the car new in 2002 ran nitrous and never tracked it, but so many people locally were getting on me about it so i made my debut
i so forgot what the rush was like... i may have to go back in a couple weeks
btw the temp was 89 degrees out, humidity @ 15, absolute barometer 29.80
Old May 24, 2007 | 02:45 AM
SStolen's Avatar
You drop your 60ft to 1.6 and your mid 11's but I'd be pissed with anything less than 135mph with that much power. You better throw some drag radials on there and come back with a better trap speed.
Old May 24, 2007 | 05:13 AM
EPP's Avatar
EPP
You'll get hooked again, good to see you're up and running. Bob
Old May 24, 2007 | 05:59 AM
cablebandit's Avatar
nice times. My car with incons at that power would usually run your et/trap on street tires and then run mid to low 10s all day long on good tires. I know you didnt have traction probs JUST at the start but for much of the 1/8
Old May 24, 2007 | 08:17 AM
SVC707's Avatar
i was fighting first and second gear feathering the gas the whole way....
youre right bob, this could get addicting again lol
Old May 25, 2007 | 08:37 PM
SVC707's Avatar
are the bfg dr the only tires i can get to fit my 18's in a 295-35-18, reason being is these are still in the 26" range verses 315-30-18 are only 25 some inches
Old May 26, 2007 | 05:58 PM
BadgeZ28's Avatar
I thought the best approach with street tires was to do no burn out and drive around the water box to keep them dry?
Old May 26, 2007 | 06:06 PM
kp's Avatar
kp
Thats 10 second mph, harder launch, better tires and shifting hard should get you in the 10s. Easier said then done though Good luck wth it and have fun.
Old May 26, 2007 | 06:11 PM
99Z28LS1's Avatar
nice times for street tires ha ha...... looks funny when people are like what the...... thats slow and then they see the mph and are like wait a second.......
new tires and harder launch
Old May 26, 2007 | 08:32 PM
GrahamHill's Avatar
Congrats! Looks like you have a good chunk of ET left with speed-shifts and a little more tire+2step
Old May 26, 2007 | 09:59 PM
engineermike's Avatar
Originally Posted by SStolen
...I'd be pissed with anything less than 135mph with that much power.
Ditto. I'm pulling 146 mph at full weight (~3750 lb) with "only" 695 rwhp.
Mike
Old May 26, 2007 | 10:11 PM
the_merv's Avatar
Veteran: Air Force
Nice.. it's got the Speed, get the 60' down and it will get there..
Old May 26, 2007 | 11:10 PM
SVC707's Avatar
im not pissed, about my times... as my friends say while watching it... "why are you driving down the track" this is the first time ive actually driven the car that hard. couple weeks ago i did 200 miles of street and canyon twisties... ill be back with some drag radials on my 18's in a couple weeks.
the more i watch the vids it teaches me to focus on certain points... like it has been mentioned; launch harder and shift harder... right now i launch as if on the street and the light turned green at the intersection
Old May 27, 2007 | 03:44 AM
nvmy2000ss's Avatar
There is definatly some potential for some great times. I would find some rims in the for sale section and put some m/t ET streets on them, I would think you should see 10's with a good launch and some quiker shifting.
Old May 27, 2007 | 04:36 AM
Got Me SOM's Avatar
with your power level i'd expect more mph out of it, even if you were feathering it a little bit.
Old May 27, 2007 | 04:58 AM
SVC707's Avatar
on the third run i was, mad cuz the car rolled back and red lit on me. and needless to say i ran who knows what on the 1/4 but my mph was 126.67
Old May 27, 2007 | 08:32 AM
TS6's Avatar
TS6
Ditto. I ran my car the same way you did, left VERY soft (for fear of tire spin) and didn't go 100% WOT until late 2nd gear and still went 135, and I'm at 3900 lbs.
I'm not knocking your setup, we're damn near identical. I'd seriously consider getting some extra rims and tires as mentioned, and see how it runs on a good tire.
Old May 27, 2007 | 01:07 PM
nvmy2000ss's Avatar
who did you get your tune by? Synergy? Newtech?
