need some help with a FI and NOS set up
Old May 24, 2007 | 01:08 PM
Crittpen's Avatar
Default need some help with a FI and NOS set up
dont mean to bet a dead horse here used the search but didnt find the info i needed
going to be running 10 to 12 lbs of boost with a supercharger
with a FMIC
wanting to run a a 50 or 75 shot
Now
should i run this wet or dry?
should i run in before the intercooler or after?
i have a Granitelli MASS but i was thinking about a speed dents tune and not even running a mass
what are you guys doing?
what do you think would be a better set up for the street
thank you for your time
Old May 24, 2007 | 01:22 PM
jeffboy757's Avatar
ive heard your MAF only reads up to 500 whp. so you cant spray a dry shot thru the maf if its already maxed because it wont add the extra fuel. if you go SD when you def need a wet shot. im only going to use some nitrous with my turbo setup because im not guuna run a FMIC and itll be far more effective
Old May 24, 2007 | 10:50 PM
Crittpen's Avatar
granatellies max out at 500rwhp or is that the stock one
Old May 25, 2007 | 12:48 AM
Ed Blown Vert's Avatar
I run a wet shot using the NX MAF kit
Old May 25, 2007 | 11:23 AM
Bad30th's Avatar
Ditto, NX wet MAF kit here too.
Rob (Bad30th)
Old May 25, 2007 | 12:03 PM
Frost's Avatar
So EVERY TIME you get into boost on the street nitrous will spray? Why?
A nice meth system will give you octane value AND IATs below ambient...
