700whp - Which clutch?
I'd vote for the same clutch setup that is in this car... if you can afford it. My Th400 cost as much as a good clutch setup.
Pedal pressure is pretty light really and only complaint is that it makes a rattling noise when you push in the clutch. Most twins do that but their are bunch of new generation that don't. Ram has street twin, it requires think adjustable master. Mcleod also think uses their adjustable master. Some have had bad luck with the mcleod masters. Tex don't use adjustable master and their 0z 700 is rated 700ft pounds. Fidanza has also just just come out with street twins for our car. They advertise light pressure, no push in floater rattling, and great grip and think are offered in 650 ft pound and 825 ft pound version. So they could be another option.
I may consider optional discs that Peter at textralia mentioned I could get for my tex twin. I have the metallic dics and they do have an organic/kevlar or something too but didn't now it was an option when bought my clutch. Maybe tex can come out with an upgrade no rattle floater thing. But with stereo on and exhaust and heater fan you can't really notice it too much and it does it only when pushed in. Still quiet is better.
So there are three twins that are street twins..mcleod, ram and fidanza. And clutchmasters might also have fx600 street twin for our cars they are making them for imports.
Be warned the twin discs are not cheap but most include flywheel for the price.
Its a superb clutch, and holds a lot more than its rating suggests. If its a daily driver, then its hard to beat.
I dont care what anyone says, the smaller diameter multiplates are not as nice to drive ( unless they used organic linings, then they could be )
Im on a triple now, and I can live with it. But mine isnt a DD...just a toy, although I did something like 6500 miles last year. So probably had around 8,000 on my OZ700..
Only replaced it because I was upgrading my T56 too....it certainly didnt need replaced !!
how often are you sitting with your foot on the clutch ? if its enough to annoy you, then IMO you are driving it wrong.
And I was actually surprised mine doesnt rattle noticeably.
I only opted for the triple, as the more friction area should provide smoother engagement.
Its not quite a plug n play install though. With hindsight......I prob should have just went for the twin...or even just stuck with the OZ700..
ya just get these ideas into your head, you need more, when you know in reality you dont.
That said, its in and driving fine. I think it would crack me up in heavy stop-go traffic, but I havent come across that scenario just yet.
Just said why have to deal with the noise if it can be designed out. So far I think my twin is pretty streetable and should get more so as the miles go by and try a few hard launches after 500miles or so. what break in did you do on the triple. How is hte pedal pressure? the twin is not that heavy at all.
I cant relate to yours as my car will use a different master cylinder. ( I changed to a larger bore size due to other problems.....was un-necessary in the end though )
But it is heavier than the OZ700, thats for sure.
No break in....I was racing, albeit at a crap track with less than 300 miles on it, and driving it hard within 100 miles on the road.
I was having issues at the time, and clutch/tranny was apart a few times with very few miles on them. Id say my clutch was fully bedded in with very very few miles on it.
I would think fitment of a few springs on the posts could help reduce the rattle. But as I said, my floaters are a pretty neat fit, and I dont hear any rattling. That said, engine/exhaust/blower isnt exactly quiet either.
