Got the first of my OFI parts!!
Thanks!
looks familar too... hmmm..
I got my parts in also.. My BOV flange is different and i believe yours is for a t4. Nice kit huh? Let see who gets it running first huh?!
Quality of the welding sucks big time and I have the exp to say that because I am a CWI (Certified Welding Inspector)
... those welds are fine for a turbo kit. I have seen worse and I have made worse welds
I understand about having to cut the intercooler pipes to fit but having to dent the down pipe in certain spots to clear the steering shaft and alternator rear most bracket
It fired right up and ran like a million bucks, no leaks... loud with open DP though hahha
turbo makes no noise idling or free reving, if i bring it up to about 2500 and hold it there it will start to quietly spin up.
Still need fans yet to be able to put the front end back on and drive it...
Even though the kit is designed to leave the alternator in the stock location, you could always relocate it like everyone else on top. Or, which was suggested by a few ppl, save off the rear bolt/bracket of the alternator... that should yield a bit more room.
besides that, i had a feeling the downpipe would need a bit or massage... its a TIGHT squeeze through there so a little ding to make things fit flush wont fill ya. Look at it this way, when your ripping it up out there, on gto's for example, that little ding wont even be in the back of your head.
laterZ!
It took FOREVER to get coolant into and full through that little tank that comes with the kit on the driver side of the car. H ad to use a little compressed air to help force feed it on there... Even with the cross over tube/vent loose on the heads to allow an air escape... Took about 3 gallons on coolant before i finally had coolant coming out that head vents.
It supposed to have 2 SPAL 13" pushers that are powered by the stock wiring harness. But those are taking a long time... im gonna just order them my self this week so i can drive this thing.
I have to drill a hole for the IAT yet and meth injection nozzle in the upper feed pipe.
Gotta be zip tied though. My shiny coating is not shiny anymore...just dull grey
