MAF 11250 Hz limit
Old May 4, 2003 | 06:07 PM
Blown Hawk's Avatar
Default MAF 11250 Hz limit
Once my MAF hits 11250 Hz fequency it levels off at 439.20 Flow gm/sec. However the table goes all the way up to 12000 Hz. The graph is an exponetial rise, not linear. So how can I complete the curve up to 12000Hz? Mighty Mouse was telling me that I can utlize my stock MAF and raise the limit to 12000 Hz toi handle my new procharger.
Thanks for your help guys,
Mike B.
Old May 4, 2003 | 06:49 PM
red ws6 99's Avatar
Default Re: MAF 11250 Hz limit
Take the stock data (frequency vs flowrate) into excel or anyother spread sheet. Add an additional point of 12000Hz and 512 g (512 g is the max the computer will handle). Plot the data in a x-y graph or use one of the curve fit equations. If you use the x-y graph you can then do a curve fit to the data. You can try expontial or poly (of different orders). You want to check boxes that ask to print the equation and the "R" value. Whatever the curve fit type you want the "R" value to be closest to 1 (which means perfect fit). You then use the equation it spits out and plug back in the numbers to generate a new curve. Or you just get one of the many excel files built for this already or find someone with the correct info. Gary
Or here is a sample:
rpm Flow Gm/sec
1500 2.32
1625 2.7
1750 3.15
1875 3.65
2000 4.16
2125 4.73
2250 5.36
2375 6.05
2500 6.8
2625 7.64
2750 8.53
2875 9.47
3000 10.43
3125 11.45
3250 12.56
3375 13.78
3500 15.09
3625 16.49
3750 17.98
3875 19.58
4000 21.26
4125 23.03
4250 24.91
4375 26.88
4500 28.95
4625 31.13
4750 33.4
4875 35.78
5000 38.28
5125 40.93
5250 43.73
5375 46.69
5500 49.8
5625 53.07
5750 56.51
5875 60.11
6000 63.88
6125 67.8
6250 71.9
6375 76.16
6500 80.58
6625 85.16
6750 89.91
6875 94.83
7000 99.93
7125 105.2
7250 110.65
7375 116.28
7500 122.12
7625 128.15
7750 134.38
7875 140.87
8000 147.59
8125 154.53
8250 161.72
8375 169.15
8500 176.82
8625 184.73
8750 192.82
8875 201.15
9000 209.74
9125 218.61
9250 227.77
9375 237.26
9500 247.08
9625 257.27
9750 267.86
9875 278.88
10000 290.34
10125 302.31
10250 314.81
10375 327.88
10500 341.56
10625 355.91
10750 370.95
10875 386.76
11000 403.36
11125 420.83
11250 439
11375 451.13
11500 463.26
11625 475.39
11750 487.52
11875 499.65
12000 512.00
Old May 4, 2003 | 07:59 PM
Blown Hawk's Avatar
Kickass Red. That's exactly the info I was looking for. Thanks bro...
BH
Old May 5, 2003 | 07:59 AM
MIGHTYMOUSE's Avatar
perfect answer gary and maaaan do i wish i could do that too
