new motor today and need help with fuel?
what cam are you going with?
+hp! what do you mean new lines two 340 intank but change lines (rubber). What about ractronics dual intank?
I ment you should get new, bigger fuel lines from the tank, as the stock ones wont do that well for the 650-700hp your attempting.
you still keeping this an auto-X car?
Here are a few pics:
https://ls1tech.com/threads/showflat...31&fpart=1
50's should get you to 600RWHP, you'll need to go to a wet shot if you plan to spray it. You'll be on the edge of the MAF range by that point on boost. Dual 340's in the tank would work well.
I would convert to a full returning system, regulator near the rail. You get too much pressure lag with a dead head into the rail like the stock setup. The stock feed line is equivelent to a -6 line, i say use it as the return and add a -8 feed to an referenced regulator.
