Catch can eliminator!!
Old Jun 19, 2007 | 10:20 PM
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
Default Catch can eliminator!!
Check this out...
http://forums.corvetteforum.com/show....php?t=1736456
Old Jun 20, 2007 | 06:41 AM
MIGHTYMOUSE's Avatar
lots of cars use a metal mesh piece of similar construction
the point is for oil to hit and stick to the fibers that are all out in the air stream, but if it has nowhere to drain down to then its gonna clog.
this set up in a vertical situation with a reservoir is the best solution... a catch can
