Best buildup for blown 6.0L
Old May 8, 2003 | 05:44 PM
blown4now's Avatar
Default Best buildup for blown 6.0L
I'm curious as to what parts everyone here with a blower or turbo setup uses and recommends. I know it's going to vary, and that's what I'm looking for. Plan on using stock crank, and stock displacement other than a little .030" overbore. ARP studs and bolts for the bottom end, but as far as rods/pistons, stuff like that, what does everyone recommend. I have the aluminum 6.0L heads which I'd like to use and have ported, but by whom?? TEA?? MTI?? Local shop sufficient? Probably use a LS6 intake, with an ATI setup (very unlikely this motor will see a turbo, but ya never know). ATI is just down the street, and I have two friends that work there. Probably going to use a t-56 trans, and a 12 bolt with a 4-link in rear. Plan right now is to put this in a early model S-10, but I saw another clean Monte Carlo today, so I'm going to check around on an 86ish Monte Carlo too. What do you blower goons think?? I've had a turbo motor, and a blower motor before, so I know of good parts, but this will be my first LS1 style buildup. Thanks.
Jake
Old May 8, 2003 | 06:59 PM
Holes02's Avatar
Default Re: Best buildup for blown 6.0L
You may want to PM BigBos. He's building a rather nice setup as we speak. ATI Procharged (D1-SC) 6.0L block. Diamond Pistons. Eagle Rods. Stock Crank. TEA ported heads (73cc chambers). It's backed with a TH400 and a 12-Bolt as well.
Old May 8, 2003 | 11:18 PM
BIGBOS's Avatar
Jake I replied back to you...I didn't list parts that I used though..
Chris (holes) pretty much summed it up..
Stock Crank, 6.0L Iron Block honed .40", that will make for 372c.i., Diamond boost pistons to handle about 20psi, Eagle H-beam rods, rod bolts, new bearings, new SLP ported oil pump, timing chain, and I also ordered a 7.85" crank pulley and a 3.60" blower pully for about 12psi....should make around 600rwhp through the TH400 & 12-bolt, I hopefully will hit the 12psi I want to see...
