Anyone running 418 cid with boost?
Old Jun 29, 2007 | 02:51 PM
theblur98ss's Avatar
Default Anyone running 418 cid with boost?
I was browsing for a new setup and I came across a 418 offered by canadian performance. It had a 4.1 eagle crank listed. Has anyone ran one of these with boost? I thought I remembered hearing that it's not good to have a longer stroker then bore but I could be wrong.
Old Jun 29, 2007 | 03:31 PM
2000 Tran Zam's Avatar
im supposed to be having my 408 bored out to a 418, however I dont know exactly if its a for sure thing so once I hear back from the motor company I can let you know...
but normally boosted setups Ive seen are either 346, 347, 364, 370, 383's on occasion, 402's and 408s (and 427's)...
Old Jun 29, 2007 | 04:47 PM
ls1290's Avatar
Dumb Ass Vette Moderator
I know several people that are build L92 block for boost. The stock bore is 4.065 and can get 416 with a 4.00" stroke crank. A little honing to get a 418 would be easy. Shirl Dickey make a 433 using a L92 block overbore to 4.1 using a 4.1 crank. He went with a high compression setup to road race, but there is not reason why one could not be done the same way for boost. According to him, the overbore still left plenty of cylinder wall thickness. I am serious looking at using a L92 block here
Keith
Old Jun 29, 2007 | 08:47 PM
red beast's Avatar
4.080 bore and 4.00 stroke with L92 block, but don't ask how I know...
Old Jun 29, 2007 | 08:49 PM
The setup I'm looking at is 6.0l block, 4.03 bore and 4.1 stroke.
Old Jun 29, 2007 | 09:31 PM
SuperZ's Avatar
from what Ive seen you don't want to go with the 4.100 stroke on a boost or nitrous motor.Its somthing to do with the piston rings and having more blow by.
Old Jun 29, 2007 | 09:42 PM
BIG BAD BLACKSS's Avatar
Piston is too short and the wrist pin protrudes into the rings possibly? I know older 347 ford strokers had issues with that.
Old Jun 29, 2007 | 10:27 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
Keith
alot of the l92 blocks, including one of my own, the sleeves actually sit crooked in the block. then when they are bored the sleeve thicknesses on either side could vary by as much as .020" +. but i had word that some of the newer l92 blocks the sleeves are in straight. just some food for thought
Old Jun 29, 2007 | 11:47 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The problem is that it moves the pin further up into the piston making ring packages difficult. Also with the iron blocks having some of the shortest sleaves of any factory block combined with the long stroke it pulls part of the piston out of the sleeve. It can lead to having blow by and oil consumption issues.
Old Jun 30, 2007 | 04:02 PM
GueSS Who's Avatar
Bigger bore
smaller stroke
Better in every combination.
Old Jun 30, 2007 | 11:42 PM
OWN3D BY MY PROF!
Originally Posted by GueSS Who
Bigger bore
smaller stroke
I don't agree with the every situation. Do you read about the engine master's challenge? The past few years have been dominated by long stroke / small bore combinations.
Old Jul 1, 2007 | 06:55 AM
Mr.MartyStone's Avatar
Look at the limits imposed on those engines for RPM requirements. That changes everything! Plus they're just dyno queens, not built for endurance of any sort.
Marty
Old Jul 1, 2007 | 09:16 AM
ls1290's Avatar
Hmmmm... good to know info
Keith
Old Jul 2, 2007 | 12:02 AM
OWN3D BY MY PROF!
Marty
Also look at the limits of the gen 3 blocks. Makes a lot more sense then. Unless you want to resleeve at the price of a kidney.
Old Jul 2, 2007 | 12:06 AM
Inspector12's Avatar
TT-TECH Veteran
Yeah I have a friend with a 418 darton block with an F1C on it and it runs good.
