SLP high-capacity radiator and intercooler
Old May 10, 2003 | 10:42 PM
AlienDroid's Avatar
Default SLP high-capacity radiator and intercooler
Does anyone know if the high-capacity radiator will fit behind the turbotech intercooler? Is that radiator thicker?
Anyone else with the 6.0 iron block, does your oil pressure in idle get as low as 26-30 psi when engine is warm? It's over 40psi when driving but low in idle. Is it the dyno oil I'm using for break in?
Old May 11, 2003 | 07:56 PM
Black LS1 T/A's Avatar
Moderator
Default Re: SLP high-capacity radiator and intercooler
Yeah... my oil pressure (synthetic) is quite low at idle when the motor is heated up. But, when I'm cruising or WOT I have full oil pressure.
