Valve Cover Adapters
Old Jul 14, 2007 | 03:09 PM
TT402LS1's Avatar
Default Valve Cover Adapters
I would like to remove my breathers and rubber grommets from my valve covers, and "tap" in an -10 fitting, so I can run a breather tank set up. Does any one make an adapter to do this WITHOUT welding to the valve cover? I have Speed Inc. billet AL covers. Any thoughts or ideas are welcome.
Thanks - Ron
Old Jul 14, 2007 | 05:45 PM
Jeff@TotalPerformanceEng's Avatar
You could try a bulkhead fitting with an o-ring and a LARGE npt end. They sell them in -10 size. Your only problem is gonna be the depth and width of the threads. I think the oil fill opening is like 1 1/4".
What I did on my drivers side was took a thick pcv grommet and installed it. Then I took a -10 fitting with an NPT end and threaded it into the grommet. It works perfectly. The rubber of the grommet seals and holds the fitting in perfectly. After that, ran a 90* -10 swivel fitting. I have zero leaks.
You could easily do this on the pass side.
Thanks - Ron
Old Jul 15, 2007 | 03:05 PM
TT402LS1's Avatar
Thanks! I was wondering about doing something like that! I will look into it. Thanks again for the info!
Ron
